4 spd manual
Old Oct 25, 2004 | 08:26 PM
no_car_yet's Avatar
4 spd manual
my dad got a line on a 4 spd manual trans to fit the 305....question is will it fit the camaro(same driveshaft length?) camaro currently has a 3 spd auto from a blazer k5
Old Oct 26, 2004 | 04:48 AM
ede's Avatar
ede
fit yes one way or another, work not without a boat load of work. drive shaft length is variable for less than 100 dollars. i'd worry more about clutch linkage and torque arms.
Old Oct 30, 2004 | 02:07 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
IS the tranny a borg warner or a saginaw? You must use a specific bellhousing that came on the 82-84 camaros and firechickens. The 4spd is mounted straight up as the 5 speeds are tilted at 17 degrees so you cant use a T-5 bell housing. Lakewood makes a bellousing PN 15020 that will allow you to use the hydraulic clutch setup or you will have to buy a mechanical setup. Hope this helps.
Old Oct 30, 2004 | 09:45 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Lakewoods bellhousing for mechanical linkage cars ('82with 4 speeds/'83 5 speed) is part #15015.
Old Oct 30, 2004 | 10:09 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
if its a saginaw your current crossmember and driveshaft will work perfect.
but the tranny will blow up extremely easily. I went through two in a month in my wagon with about 330 hp
Old Nov 2, 2004 | 08:43 PM
Xhiron's Avatar
Car: traded away 94 v6
Engine: vacant
Transmission: also vacant
If its a Super T10, have fun finding a 32 spline th400 yoke for it (I've been scrounging for 6 months here now, no avail) and you'll need about an extra inch on the driveshaft to fit. I don't know how you're gonna fit either a slave or mechanical linkage, try scavenging an older car.
Old Nov 7, 2004 | 08:56 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Try this...
http://fiedlerh.home.att.net/BW.htm
and
http://www.tiltonracing.com
browse around until you find the hydraulic throwout bearings
Old Nov 8, 2004 | 03:54 PM
groundrat's Avatar
Car: 91Z28
Xhiron:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33727
http://cgi.ebay.com/ebaymotors/ws/eB...category=33733
Old Nov 9, 2004 | 01:18 AM
Xhiron's Avatar
Engine: vacant
Cheap those be not! I know you can get new ones, its the used ones you can look high and low for and never find.
Old Nov 9, 2004 | 08:53 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
No-car-yet--so what kind of 4 speed is it? If you're running a 305 it'd be a lot easier to use a T5--cheaper in the end, too.
Falcon50
Aug 22, 2020 03:26 PM
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
