Warped Flywheel causing vibration?
Old Oct 26, 2004 | 02:11 PM
3gc's Avatar
3gc
Car: Z28
I have been trying to find the source of a vibration i have and got a suggestion yesterday to back off the torque converter. I did today, the vibration was still there when i reved the motor but not as severe. I felt the vibration after about 2250 rpm - 3500 rpms. I decided to bolt everything back up and when i tried to bolt the tc back to the flywheel i noticed that the bolt holes for the torque converter are about a 1/4" away from the holes in the flywheel for it. When i tighten the bolts it pulls the flywheel in towards the tc. The TC seems bottomed out in the flywheel though. I tried my best to take a good picture of it but the best i could get was this.
So i pulled the ecm fuse and had someone crank the car over so i can see the flywheel move slowly. It's definately warped. I figured i'll just replace the flywheel on my next day off, but that dosn't explain why it still vibrates when i'm at speed, put it in neutral and shut the motor off.
Anyone hear of something similar to this happening before?
Old Oct 27, 2004 | 12:42 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Not to be picky, but it's a flexplate, not a flywheel. No, I've never heard of something like that. Are you torquing the bolts are hand tightening?
Old Apr 7, 2008 | 10:24 PM
IROCmenace's Avatar
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
Re: Warped Flywheel causing vibration?
Sorry, I now this is an old thread but I found it on a search, I have the same problem. Did you ever get this problem fixed? Was it the flexplate?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Oct 7, 2015 10:15 AM
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
