how do i find out what rear end i have?
Old Nov 4, 2004 | 10:22 AM
mcwille's Avatar
Car: 1987 Trans am 5.7 TPI
Engine: 5.7 TPI
ok i am sure that this has been answered before but i cant find where...
I have an 87 TA that is fully loaded (5.7, all wheel disks, etc...), how do i tell if it is a 9, 10, or 12 bolt rear end? what is the difference anway? i here all this stuff about them and i really have no clue what is different between them. also is there anyway to find out what gears i am running?
thanks
mcwille
Old Nov 4, 2004 | 10:30 AM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
The way that you can tell if you have a 9, 10, or 12 bolt is to get under your car and count how many bolts are holding your rearend cover on. and for gears.. there should be a tag under one of the bolts that should have stamped on it what gears you have. If your tag is missing. you can check your RPO codes and find out that way. or you can just pull the cover and look.
Old Nov 4, 2004 | 10:40 AM
ede's Avatar
ede
only way to know what gears you have is to pull the cover and do the math.
mcwille's Avatar
Engine: 5.7 TPI
i dont have my RPO sheet i really wish i did and counting the bolt WILL tell me what rear end i have someone told me that that isn't what make it a 9 or 10 bolt
Old Nov 4, 2004 | 12:01 PM
ede's Avatar
ede
someone lied to you, or just didn't know any better, counting the bolts is how you tell.
Old Nov 8, 2004 | 04:42 PM
DeWynter's Avatar
You can also tell if it is a 10 bolt what ratio is in it by looking at the stamped code on the axle housing on the front drivers side I think or maybe the passenger, but its on the front...
If it is a 9bolt its on a tag bolted to the rear cover.
Old Nov 8, 2004 | 05:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Only if nobody has changed the gears. The only way to tell for sure is to take the cover off and look. This is also a good opportunity to change what very well could be the factory original lube.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
