98+ rear
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If your stock lines don't work, it's not really a problem since for about $10 you can get new hard lines and attach them to the rubber lines off of the calipers and to the stock "T" that is on your car.
I had drums on my formula and put a 98 rear on the car, but my lines were all rusty with holes in them so I just bought 2 new hard lines, a long one and a short one.
Originally posted by NastyL98_T/A
How do you make the connection between the rubber line from the caliper and the metal line from the rear?
I then attached the metal line to the rubber hose on the 98+ Brake Caliper and then to the stock "T" fitting that is attached to teh top of the pumkin.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
