Need suggestions for future transmission plans.
Old Nov 14, 2004 | 11:02 PM
ThaBlur's Avatar
Car: 87 Std. Camaro
Engine: 305 4 barrel
Transmission: t-5
Hey, I have an 87 camaro with a 305 4 barrel and t-5 tranny, sometime in the future I hope to have a 383 stroker with a T-56. However, getting the 383 stroker will be a while, will a T-56 still work with my 305? Which tremec should I use LS1 or LT1? Any help or suggestions will be greatly appreciated.
Old Nov 14, 2004 | 11:31 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
any one of those t-56 boxes will work but if you can get a hold of one from an LS1 for a good price, i'd say go with that one and yes it will work with your 305. The aftermarket has a lot of retro-fit kits out there for bolting up a t-56 in an fbody...just do a search and you'll find a lot of info.
Old Nov 15, 2004 | 01:17 PM
ThaBlur's Avatar
Car: 87 Std. Camaro
Transmission: t-5
Ok, With an LS1 T-56, Will it work with a mechanical speedometer?
Old Nov 15, 2004 | 04:20 PM
cheyenne383's Avatar
Car: Huffy 10 speed ;)
Engine: My legs
Transmission: My wrist
Axle/Gears: Little spokey things
The LS1 T-56 will NOT work with a Gen 1 or Gen 2 small block, it will only work with an LS1. All of the T-56 transmissions have an electric speedometer, you have to either get an electric speedometer or an adapter from Dakota Digital or somewhere else if you want your speedometer to work right. Read the stickty at the top of this forum for a LOT of good info from people who have done this swap.
Old Nov 15, 2004 | 04:34 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
you can make it work with one of these http://www.abbott-tach.com/cablex.htm
Old Nov 15, 2004 | 04:35 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
keith sullivan of speedtek performance put a 98 ls1 6 speed in his 69 camaro that at the time had a 406ci 1st gen sbc. centerforce sells the flywheel, unfortunatly they may not anymore because its not currently in there cataloge. just thought id add.
Old Nov 15, 2004 | 04:48 PM
Engine: My legs
This is true, they will fit with a lot of effort. but if you're going to buy a whole transmission, it's a lot esier to start with one that bolts up with a LOT less effort.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Jk_Under
Sep 8, 2015 08:13 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
