Rear end clunk
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Rear end clunk
Did a search, while there was a ton of results, none really helped.
I'm starting to get a clunk from the rear end. It usually starts after making a turn at slow speed, but after that any time the car's moving slow I get it. Its a heavy clunk, meaning very noticible and affects the movement of the car. It happens approximately every 1/4 revolution of the wheel.
Any ideas? I took a look at the brakes and didn't see anything wrong, and there was nothing obviously wrong with the diff, no metal pieces sitting in the bottom of the housing, but of course I'm ruling nothing out.
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Check for loose Lower control arm bolts, well loose bolts for that matter, one of mine was loose after i swapped rears, and it made a clunk.
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Nope, that wasn't it, thanks though.
Now there's a higher pitched clunk that accompanies the original. Tried standing on the brakes while giving it gas and the sound was still there. Also, I forgot to emntion this the first time: the clunking only starts after I drive a while. If I try to reproduce the clunking leaving the driveway, it doesn't happen. Come home and pull in at the same angle once, and the clunking starts.
TIA
TIA
I had the same exact problem, turns out rear end fluid didn't have the special GM POSI additive, so I went to GM and bought this little bottle, poured it in and I never heard the clunking again.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Thanks guys. Apparently I didn't add it when I refilled the rear. Which means I probably threw out a full bottle of additive.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
