t-56 clutch adjustment???
Old Nov 26, 2004 | 09:48 AM
d10pins's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.70
i was wonder if there is an adjustment at all for the clutch. he is my problem, sometime i cant get there car into reverse when it is running but if i shut it off it goes in fine. someone told me to bled the fluid out because there might be air in it. its a 94 tranny. all other gears shift fine but once in awhile it wont go into reverse. the reverse lockout if working so now i stuck. thanks
Old Nov 29, 2004 | 02:13 PM
Lumberjack's Avatar
Car: '91 Z28 Convertible
Transmission: 5 speed
Have you tried shifiting into 5th gear and then go into reverse? I don't think there is any syncro's in reverse so this helps.
Old Nov 29, 2004 | 04:49 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
LOL
Its the reverse lock out solenoid. You just have to fight against it.
EDIT: Just re-read your post. How are you sure its working? I know I have toi fight mine. The t-56 does have a reverse syncro so no need to throw it in any other gear before you go into reverse.
88SS6SPEED
Nov 11, 2015 07:05 AM
camaro1185
Oct 26, 2015 06:51 AM
tonys91rs
Oct 10, 2015 03:31 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
