Loud noise from the rear end???
Well, I noticed a loud whine from the rear end recently. I replaced my tranny with a probuilt 7--r4 last year. I thought the noise was my drive shaft loop. I took it off and i still have the noise. It sounds like a loud dull whine and it gets bad under decelleration. I also hear something rattling when I"m at low speeds? I did a search but I'm not sure what direction to go with this problem?
Any help is GREATLY APPRICIATED
Well, the noise got worse and worse as I drove. I stopped by bhaas's house and we noticed the driveline was slightly bent. On my way home the knock got louder and louder???????? the knock got louder and faster the faster I went. Put the car in N and the knock rate stayed the same???
Ede,
thank you for the responce! I jacked it up, took off the dirve shaft and then tried to spin the wheels. Clunk every rotation. I think my rear end is gone
So what rear ends fit our thirdgen's? I have drum brakes in the rear?
Thank you for your help
Car: 1984 Camaro Z28, 1987 Z28 (R.I.P.)
Engine: 305 H.O.
Transmission: 5 Speed
I think my car's doing the same thing has your, I thought it was maybe my exhaust but now that I think about it it might be my drivetrain (Should stop doing donuts) or my transmission..
I would check under car.. but its too ****ing cold in Canada right now!! haha Can't wait to get this car off the road.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Off to the junk yard. So how do i change my spedo gear if i get different gears?
