Another TC lockup question
Old Dec 2, 2004 | 12:04 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Ok, before everyone gets mad at me....I have read the tech articles and done a search on the subject. I understand how to manually lock up my TC. The problem I am having is that the connector that plugs into the transmission is broken and will not plug in. My question is: how do I properly run a wire from my ignition source to inside the transmission? I'm sure it can be done but I need some help from you experts. Thanks.
By the way, the reason I need to manually lock the TC up is because my heater core broke and spilt hot coolant all over my ECM, causing it to stop working. I then put a non-ECM carb and distributor in.
Bubbajones_ya
Aug 31, 2015 12:02 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
