t-5 swap questions
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
t-5 swap questions
first off....did anyone who has done this swap have any problems with vibration? also, does the center of the shifter mount on the tranny mark the center of the hole to be cut into the floor pan?
Car: 87 IROC
Engine: mini-rammed 350
Transmission: WC T-5
I seem to feel a bit more vibration than I had with the 700R4,but with the T-5 I leave my hand on the shifter more,so it could be my imagination.
As far as the hole goes,its pretty much centered over the square shifter mounting hole(on top of trans),maybe it's a bit offset to the drivers side on the tunnel itself
Hope that helps
Steve
Hope that helps
Steve
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I feel some vibration but I think that is because of the poly trans mount I installed. I also installed a poly tq arm bushing too.
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Car: 91 rs
Engine: 250
Axle/Gears: stock??
i don't have any vibration that i can tell of. i used a poly ES mount. and no problame with that. just gotta use that spacer and thats what i've been told. MAKE SURE you get all the pices to the puzzle
