Worn out/ stretched T.V. cable...
Old Dec 10, 2004 | 08:03 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I was just wondering on the posibility of the T.V. cable to become "warn out" or stretched over time. I just put $1700 into my trans and my T.V. cable has 160,000 + miles on it. I wanted to know if these acctully wear out or stretch over time.
Kevin
Old Dec 10, 2004 | 10:17 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I'm not sure if they stretch over time, or if internal wear in the trans makes them too long. They do self adjust over time to compensate for one or the other.
If you've got $1,700 tied up in your trans I'd say that spending $30 on a new TV cable is small potatoes to be absolutely sure.
BTW, I'd get one directly from GM. The OEM quality is better than every "parts store" cable I've ver seen.
Old Dec 10, 2004 | 11:20 AM
Engine: L98 350 TPI
Why thank you very much!
Kevin
Old Dec 10, 2004 | 01:24 PM
No problem, good luck with it, sounds like a fun car from the description in your sig.
Old Dec 10, 2004 | 02:55 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
bowtieoverdrives has the tv made ezee cable for 18 - 35 and detailed online instructions. i have it and have had no problems.
morrow
Jan 13, 2024 12:29 PM
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
Street Lethal
Sep 7, 2015 01:09 PM
