TV cable slipped?
Old Dec 14, 2004 | 07:40 PM
ThePr0's Avatar
Car: 91 t/a
Engine: 91 350 tpi stock
TV cable slipped?
Today I was driving 25mph and accelerated lightly to 35, and noticed it hadnt shifted. Drove it around some more and it seemed it wouldnt shift out of 1st until 4000rpm, so I adjusted the T.V. Cable by pushing in that button on the side of the cable near the t-body, and slid the tube on its transmission side toward the front. Drove it around, shifted hard, so I adjusted it back a little, seems ok.
My question is, what could cause this to just happen all of the sudden, and will it happen again soon? Did this fix the problem?
Could there be other problems that I am missing?
Thanks.
Old Dec 15, 2004 | 07:55 AM
ThePr0's Avatar
Car: 91 t/a
UPDATED
Drove to work this morning, shift point has already changed and it shifts kinda jerky. Could cold weather effect this? Its 30F here.
Old Dec 15, 2004 | 09:53 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Cold weather can affect the way a trans shifts, because at first the fluid is cold, and has different properties than warm fluid. Sounds like the beginnings of transmission failure. When you auto adjust the TV cable does it still have adjustment left, or is it maxed out? If it's maxed repalce the cable and see if the problem persits.
Old Dec 15, 2004 | 02:47 PM
ThePr0's Avatar
Car: 91 t/a
seems to have a little adjustment left, i have a cable from a parts car i can swap out and give it a try.. thx
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
