V6 700r Question ?
Old Dec 30, 2004 | 08:53 AM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
V6 700r Question ?
i have a 87 camaro v6 with 700 auto. when i go from a dead stop and the gas to the floor the car wont get out of its own way, but once up to speed it seems to shift fine. time to rebuild ? any thing i can check out ? i changed filter and fluid to no avail, old fluid didnt look real bad.
Old Dec 31, 2004 | 03:12 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Are you sure it's a tranny problem? Sounds like a clogged exhaust converter, dirty air filter or fuel supply problem maybe?
Old Jan 3, 2005 | 07:13 AM
SPIKE's Avatar
Car: 86 CAMARO
tom not 100% sure. motor seems to run fine in park it will accelerate and sounds great. i have recently bought this car and went through all the basic tune up stuff. i also replaced the muffler because it was blown up. i also hollowed out the cat. any thing you can think of for me to check would be appriciated. thanks.also new plugs, wires, cap, rotor, coil,o2 sensor,oil, filters,set timing,set tps,fuel pressure 45 psi.car also shakes a little when in drive and foot on brake.
Old Jan 3, 2005 | 04:26 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Did you unhook the timing set connector wire when you set the timing? Did you have to change the timing much? This could cause some trouble. Fuel pressure at 45 sounds good and the hollowed cat eliminates that possibility.
Old Jan 7, 2005 | 07:36 AM
SPIKE's Avatar
Car: 86 CAMARO
yes timing was set properly. still not sure about tranny, in past experiences when tranny was slipping rpm's would rev up but car would not move. this is not doing that it seems like motor is bogged down. not much experience with these new injected, computer deals !
84z96L31vortec
Aug 20, 2017 12:16 AM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
