LS1 t-56
Old Dec 30, 2004 | 05:05 PM
Kaas's Avatar
Car: 89 Iroc-Z
LS1 t-56
alright guys, this is going to be my next project after i get the cash...i am tierd of dealin with the crappy 700r4 goin out on me. but i've heard that it's better to go with a t-56 from a LT1 cause they bolt up easier or are a different length or something...someone want to correct me? but anyways...the bottom line is i want a LS1 with a t-56 behind it...tell me what the best way to go about it is...i was wanting to buy a parts car with it all in it so i have all the harnesses and such (cause i also am wanting to do a dash and console swap) and it's just make it much easier
Old Dec 30, 2004 | 06:02 PM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
Re: LS1 t-56
the way the bellhouseings bolt to the engine are different on a lt1 and a ls1. the ls1 is different then the regular small block. as far as getting a ls1 and a t56 the easy way and the only way i know of is to find a wrecked car and pull it from that.
Old Dec 30, 2004 | 07:04 PM
kevinc's Avatar
Car: 1982 Z28
Re: Re: LS1 t-56
Input shaft length is different also. Cheaper just to find an LT1 donor than to rework an LS1 trans or buy an aftermarket bellhousing.
The two are easy to visually distinguish, the LS1 has a hydraulic slave/throwout assembly mounted on the input shaft, where the LT1 has an external piston-type slave cylinder and fork.
Old Dec 30, 2004 | 09:36 PM
Re: Re: Re: LS1 t-56
didn't know about all that. thanks for the extra info.
Old Dec 30, 2004 | 11:39 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
FYI...check out the Feb. 05 issue of Chevy High Performance, they have an article on swapping a 6 speed into a 3rd gen
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
