Corvette 700R4
Old Jan 3, 2005 | 03:47 PM
klumb15's Avatar
Corvette 700R4
okay, when i bought my car, i was buying it from the owners son, becuz the owner had died, and the son said that his dad puked the 305 motor that was in my car, and swapped it out for a corvette motor, 1990 or somewhere around there...also i noticed when i got it, that the tranny shifted way stiffer than a usual 3rd gen did, and it was obvious that the trans has had work done to it.....my question is, is it possible to put the 700R4 from the vette into my camaro, and also how much more durable is the corvette trans, and how would i tell if it is indeed a corvette trans??cuz if the guy swapped in the motor, you would think he would swap in the trans too??is there anything that makes the vette tranny different from the camaro trans, numbers or anything to tell them apart so i know what i'm working with??
Old Jan 3, 2005 | 03:54 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The corvette case is different from other 700's. The vette trans has no bolt holes to mount your crossmember to. The vette uses holes in the tailshaft for mounting purposes. Except for the output shaft all vette internals can be installed in an f-body case. The valve body, governer, and servo is what give the trans its"character"
Old Jan 3, 2005 | 05:36 PM
klumb15's Avatar
so your saying the vette trans wouldn't really bolt into a camaro very well? is there like 1 main difference that if i went out there a looked at it, i'd beable to tell if it was a camaro or vette trans??
Old Jan 3, 2005 | 05:41 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
The case cannot be a corvette case. No holes in trans for mount to bolt to. All other 700-r4's had these holes. Very common for a rebuilder to install a corvette governor and a corvette servo. A shift kit will also inprove shift firmness and quality.
Old Jan 3, 2005 | 05:47 PM
klumb15's Avatar
alright thanks...i doubt he went the extra mile to install all the corvette parts in the camaro trans...it prolly just has the shift kit, because when i got it i found a shiftkit package that he just left in there along with tons of other crap...
Old Jan 4, 2005 | 03:13 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The "Corvette servo" also came in many transmissions in vehicles that weren't Corvettes.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
