Changing pinion seal???
Old Jan 6, 2005 | 03:12 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Well I discovered I now have a realitivly small puddle of gear oil in my driveway and its leaking down from my torque arm. There is none on the back cover, it has to be the pinion seal. I know you need to take off the drive shaft, remove the nut and pull the yoke, screwdriver the seal out and put the new one on. But how do I put the pinion gear back in correctly? Any tricks of the trade because I know people do this crap without a feeler gauge.
Old Jan 6, 2005 | 03:30 PM
brutalform's Avatar
Ive just put the yoke back in, with the washer, and tighten the nut. Mark the threads before you remove the nut. Also use a new nut, or stake the old one. It will loosen up.
Old Jan 6, 2005 | 04:51 PM
ede's Avatar
ede
do a search and you'll find a good break down on how to do it, i've typed it out more than once.
lt1z350
Sep 29, 2015 01:50 PM
gixxer92
Sep 1, 2015 04:32 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
