bellhousing bolt rounded off
Old Feb 7, 2005 | 07:18 PM
mightymouseman's Avatar
Car: used to have red 1991 camaro RS
Engine: with 305 TBI
Transmission: Borg Warner T-5
Axle/Gears: and 3.08 open 10 bolt
i have just removed my transmission and i began to remove the bolts that hold the bellhousing to the block. there is only one bolt separating me from my clutch, i rounded it off. how do i remove this bolt. im not sure if a pair of vice grips will do the job or if i have any room to fit a pair in. thanks guys. i can smell burnt clutch disk.
Old Feb 7, 2005 | 08:25 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
A smaller (13mm) 6pt socket might be able to get hammered onto it, and get it loosened . Good luck.
Old Feb 7, 2005 | 08:39 PM
VILeninDM's Avatar
I had that happen recently with a cross pin bolt in the rear end. Ended up going to Sears and picking up their easy outs (something like $50 for the larger set). They get hammered on and basically cut into the bolt as you are unscrewing it. Worked beautifully.
Old Feb 7, 2005 | 08:59 PM
thanks guys. i really appreciate that. i need to get that thing off so i can get my flywheel resurfaced hopefully tomorrow.
Hotrodboba400
Dec 10, 2019 07:07 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
jtwoods4
Sep 3, 2015 05:39 PM
jtwoods4
Sep 3, 2015 10:19 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
