FLYWHEEL, Is is worth it to change???
Old Feb 13, 2005 | 04:28 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Is it worth it to change ourt the flywheel for a lighter/heavier duty one? How long would it take....is it a pain in the *** to do?
Old Feb 13, 2005 | 10:48 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
if you have never worked on a trans i suggest having someone who has done it there guiding you and teaching you, there is alot to **** up there
porkyzilla's Avatar
Engine: 5.7tpi 350,
Old Feb 14, 2005 | 02:11 AM
EvilCartman's Avatar
Car: '82 Z28
Re: FLYWHEEL, Is is worth it to change???
Your info says you have an auto trans... You wouldn't have a flywheel if that was the case. Flexplates come with autos, flywheels come with manuals. Just incase you have a different car with a manual trans, a light weight flywheel is not good for drag use but would be ok for other types of racing.
Old Feb 14, 2005 | 05:54 AM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
I wouldn't tear it all apart to change the flywheel unless it were a competition car and I needed another edge; but if it's a daily driver and you have to do the clutch anyway, the light flywheel gives much better throttle response and makes it much more fun to drive.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 31, 2015 10:31 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
355tpipickup
Aug 19, 2015 10:02 PM
