diff swap
Old Feb 15, 2005 | 12:58 PM
hdtripp's Avatar
Car: 89 Formula
Engine: 5.0L tpi
Transmission: 7R400
diff swap
I have an 89 Formula with an open rear end that replaced the limited slip when funds were low. I want to replace it with another limited slip. What are my options?
Old Feb 15, 2005 | 01:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well, there's a few..... you could leave the one-legger in there, or maybe you could replace it again, for example. No doubt there are other options as well.
What model of rear is in it now? What gears? What brakes are on it? What kind of consition is it in? What do you want to do with the car? What's your budget this time around? All of those things would have an impact on what to do with it. Assuming of course, that out of all available options, you choose one other than leaving it like it is.
Old Feb 15, 2005 | 02:44 PM
hdtripp's Avatar
Car: 89 Formula
Engine: 5.0L tpi
Transmission: 7R400
It is the open rear with 2.83? gears. It has drum brakes. I have thought about disc brakes, but I think the swap may be more complicated than I want to tackle. I have seen the spools that you can put in, but I don't know what's involved, and if it will work. Right now, all that is wrong with it is the seal on the left side of the axle is leaking and needs to be replaced. I am just curious about the replacement spools, mostly.
draco
Oct 4, 2015 09:25 PM
ydnar417
Sep 23, 2015 05:57 AM
LittleFranks
Sep 17, 2015 12:22 PM
mddaniel
Sep 8, 2015 05:16 PM
E Rod
Aug 28, 2015 05:17 AM
