Bad to drive around in OD?
Old Feb 17, 2005 | 01:08 AM
Gimmeadonut's Avatar
Hi there,
I have been told by many people that its very bad to drive around say "in town" while your in Over Drive. Yet some say its perfectly fine to drive around in Over Drive, its just using a differnt Gear ratio. or something of the sort.??? ANy Ideas??
Attempting to save some gas=p
Old Feb 17, 2005 | 03:28 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
It used to be bad, I'm pretty sure they fixed all those problems by the time thirdgens hit the market. If you've got a trailer then dont use OD.
-chillen
Old Feb 17, 2005 | 06:54 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The 700R4 dose not shift into OD until you hit 40 MPH, so when you drive around town you are in 3rd gear until 40 MPH. So it makes no difference, keep it in OD.
Old Feb 17, 2005 | 08:12 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Only time you need to shift into 3rd is if the transmission starts hunting into and out of overdrive or the converter clutch starts hunting as in mountain driving. Letting the transmission continually upshift and downshift overheats the clutches and fluid, leading to potential failure. Other than that drive in OD
Old Feb 17, 2005 | 10:13 AM
Thanks GUys!
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
Bryan F
Aug 18, 2015 02:28 PM
Out-Cast
Aug 17, 2015 10:57 AM
