Correct stall for my setup
Car: 1992 Camaro RS
Engine: 305 V8
I will be buying a 4L60E soon that is built pretty well (can take 500+ HP) and I can either get it with a 1200 or 2000 stall converter.
It will be used with a LT1 that should be making around 410HP to the wheels.
I have a Borg Warner 9-bolt with 3.27 gears.
I really don't know much about torque converters.. this car will be a daily driver so I'm looking for the best converter for this application. What do I need?
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Your converter should be matched to your total combo...cam, heads, gearing, ect. The intended usage is important too, theres always a compromise between speed and reliability. If you don't drive it on long highway trips and having the best 1/4 mile time possible is important to you go with a higher stall. If you want the most reliable setup and don't want to worry about heat problems shortening the live of the trans and converter go with a lower stall.
I don't know your total combo but with 410RWHP your LT1 is pretty stout and probaby best suited for 3.73-4.10 gears and 3000-3500 stall for maximum performance. But since this is a daily driver I would go conservative on the torque converter especially if you plan on keeping the 3.27 gears....I would suggest a 2500stall and a quality trans cooler. That would be a good compromise, decent performance but you wouldn't have to worry too much about heat build up as long as you have a good trans cooler.
I would also suggest you call several manufacturers tech lines and tell them your total combo and see what they recommend...its always good to gather all the info/opinions that you can.
Car: 1992 Camaro RS
Engine: 305 V8
What about a 2000 or 1200 stall?
With the transmission that I'm getting, I can get either one for free.
This is NOT going to be primarily a race car, but I don't want it to be bogged down. Would I need a trans cooler with a 2000 stall?
Hmm... anyone know what the factory stall converter is with a 700 r4?
Car: 91 z28
Transmission: 4l60
if you look on your converter, look for a sticker with 4 digits, the second digit is E=1654, F=1611, G=1397, i just pulled mine from 91 z28 w/305, its an E
If you want to get one for free and have to choose between 2000 or 1200, I would definately go for the 2000. And to be on the safe side, get a trans cooler that way you won't have to worry about it ever heating up. They don't cost that much and are easy to install, its definately worth it.
Street Lethal
Apr 30, 2019 12:14 PM
C409
Sep 1, 2015 03:42 PM
