Anuto to manual... ECM need changed?
ECM is the same so no change needed, but you may want to change software. Check out the DIY-PROM forum.
When I swapped in a T56 on mine, idle behavior was strange until I burned a chip with manual trans bit set. It would "hang" the rpms while coasting to a stop, etc. Just a nuisance and not a show-stopper, but it was annoying.
