1991 RS Rear
Car: 1991 RS
Engine: 305 TBI
1991 RS Rear
I have a 1991 Rs, it has 2.73's and an open rear. I want to improve performance, and am looking for 3.73's and to swap out my differential. I do not understand what carrier I need when replacing, since I have 2.73s and open rear. What are some good differentials and places to get them. Also do I have the 26 or 28 spline axles?
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
If factory you have 28 spline axles and for a 3.73 you would need a series three carrier or special gears made for a series 2 carrier. My recommendation is to find a fourth gen rear with posi and disc brakes and then swap them onto a V6 third gen rear, that is my plan. The search button is also helpful.
Car: 1991 RS
Engine: 305 TBI
thanks, i think i am going to order 3.73's made for a series two carrier. but what about the posi, when looking at posi's i see ones for greater than 3.08 or 3.08 and down. I was wondering would i need the 3.08 and down since my carrier was originally 2.73's or do i need for greater than 3.08 since i now have 3.73's.
Car: 91 Camaro RS
If you are going to get all new gears and posi just order a series 3 posi and series 3 gears. Just for clarification Series 3 is 3.23 and lower (higher numerically) and series 2 is 3.08 and higher (lower numerically) series 4 is something around 4.56+.
Car: 1991 RS
Engine: 305 TBI
But if I would get a series 3 gears and a series 3 posi do i need to change my carrier or does everything just remain the same? because i thought i would need a new one, or is the posi differential itself the new "carrier."
Car: 1991 RS
Engine: 305 TBI
I'm kind of confused.. can someone tell me the best way to go for new gears and posi if right now i have a stock 1991 RS rear 28 spline, open, 2.73's. Like what should I get, part numbers and any other opinions. Thanks a lot!
Car: 1991 Chevy Camaro
Engine: 305 TBI
3.73 gears (Motive):
http://www.thunderracing.com/catalog...&vid=6&pcid=67
Part number 69-G875373
Positraction (Eaton):
http://www.thunderracing.com/catalog...vid=6&pcid=279
Part number 185-19599-1
You'll also need the gear install kit (Ratech):
Part number 85-3001K
bjpotter
Jan 22, 2019 12:27 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
