89 Iroc rear question
Car: 84 Z28
Engine: 305 HO
A friend of a friend of mine has a rear from his 89 iroc, the car was totalled like 10 years ago, so he only has the rear. The car was an 89 Iroc 350 TPI Automatic... He says it has a posi and has disc brakes. On the tech sheets it shows only a 2.77 and a 3.27 gear ratio. He also thinks the posi needs to be rebuilt. How much do you think the rear is worth? What gears do you think are in it? My 84 has 3.73 open, and my guess is they wont work in that rear, is this correct? How much would it be to rebuild the posi? I think he said it only needs to be shimmed. The other thing is I have drum brakes, so I guess I would need a new proportioning valve, whats that cost? Please any help would be great.
Transmission: 4L80E/4L80E
Re: 89 Iroc rear question
Originally posted by 70BuickSleeper
A friend of a friend of mine has a rear from his 89 iroc, the car was totalled like 10 years ago, so he only has the rear. The car was an 89 Iroc 350 TPI Automatic... He says it has a posi and has disc brakes. ..The other thing is I have drum brakes, so I guess I would need a new proportioning valve, whats that cost?
On the tech sheets it shows only a 2.77 and a 3.27 gear ratio. ... My 84 has 3.73 open, and my guess is they wont work in that rear, is this correct?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
you think its worth the risk for 200/250 bucks???
mustangman65_79
Aug 11, 2015 03:17 PM
