Why?
Old Apr 16, 2005 | 02:06 PM
66GPman's Avatar
Car: 1986 TA
Why?
we swapped motors, and the 350 won't mate up flush with the t5, there's about a 3/8 inch gap. Y. we've tried everything, so how bad would it be if we just tightened it up? I know it's a big no no with an auto. But what should I do?
Old Apr 19, 2005 | 10:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Find out whats not fitting/binding/stuck.
Old Apr 19, 2005 | 10:29 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I assume that you mean there is a gap between the bellhousing and trans, right?
I just ran into a similar problem. I swapped the bronze bushing for a roller pilot bearing...and since I didn't know any better...I just pressed the bearing in far enough to be even with the crank.
The solution was to press the bearing further in to the crank and the gap between the trans and bellhousing disappeared.
