Rear Differential Help
Old Apr 17, 2005 | 07:38 PM
JMONEYTREE's Avatar
Car: 91 Camaro
1991 Camaro RS 305TBI Non-posi rear end
I want to upgrade to a limited slip. Can I put a new differential in without having to change the whole rear setup? Do I have to change out the whole rear assembly? What should I get? Specs? Thanks
Old Apr 18, 2005 | 12:21 AM
LiquidSnake's Avatar
Car: 1989 Camaro RS
Engine: L03 V8 305cid
Transmission: Borg Warner T-5
1989 Camaro RS 305 TBI 3.08:1 Open Differential
Well I just recently went to my local junk yard and had a 9-Bolt Limited Slip 2.77 Disc rear pulled from an 86 TransAm for $250 and I went ahead and grabbed the Proportioning valve from the same car which was $15 I think I havent gotten around to installing it yet though...Im in the inspection/cleaning phase
To the best of my knowledge you can swap your rear end for any rear out of a Camaro/Firebird between the years of 1982-1992 so that leaves you with many options. As long as your rear suspension is in good shape all you have to do is drop the axle and swap it. however it would seem to me that this is the optimal time to upgrade things like sway bar, control arms, shocks/springs If none of that applies to you then all you should need is Time, Tools, and one or two friends...and a couple jacks/sets of jack stands
If all you want is a Limited Slip Diff then it is simple try searching the local junk yards, or eBay
I'm not sure where you are located but I might be able to point you in the direction of a 3.73 Posi rear with disc brakes in Kingston, Ontario (about 20-30 min from U.S. border)
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
E Rod
Aug 28, 2015 05:17 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
red90IROCls1
Aug 25, 2015 06:56 AM
