what posi unit size?
Old Apr 20, 2005 | 12:17 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
im looking for a posi to change out my open diff. and i need to know what size carrier? 7.5 or 8.5? right now the car has a 2.73 open diff on an 86 z-28. how to figure this out?
Old Apr 20, 2005 | 12:20 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
It's a 7.5. The 2.73 is a 2 series carrier. Keep that in mind if you are sticking with those gears. 3.23 and up use a 3 series carrier.
Old Apr 20, 2005 | 03:28 PM
ede's Avatar
ede
or 7.62, same as 7.5. gm just wanted to confuse us a little but more.
Old Apr 20, 2005 | 09:44 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
how hard will it be to chage my rear from open diff to a posi? is all the work in figuring out the shims? anything i should really know?
Old Apr 21, 2005 | 05:05 AM
ede's Avatar
ede
r&r for the carriers is easy and doesn't really involve much in way of shimming. swap ring gear to new carrier ,check back lash, check contact pattern and you're all set. the carreir shim total thickness shouldn't be changed, the arrangement of the shims can be to correct backlash.
Old Apr 22, 2005 | 01:31 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
in all seriousness ive never taken a rearend apart, so i have no idea what you just said..any links or sumptin for the beginer in rearend?
Old Apr 22, 2005 | 07:28 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Here's a good how too. It's trucks but still GM rear ends. Lots of photos too.
http://www.fullsizechevy.com/fscu/axletech/
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
