Do I need a new bolt for the rear end pin?
Old Apr 21, 2005 | 10:11 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Tonight, I installed a set of Moser axles and had to remove the bolt that holds in the pin between the spider gears. I have read that every time you remove that little bolt it should be replaced. Where would I get one?
Old Apr 21, 2005 | 10:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
GM P/N 14056196
Old Apr 21, 2005 | 10:24 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I guess that's a yes. I'll get one tomorrow hopefully. Thanks for the part #.
Old Apr 21, 2005 | 10:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just getting it out in one piece indicates you've had a tremendous amount of luck. Don't push it by reusing it.
Old Apr 22, 2005 | 09:02 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I second that!!
Old Apr 22, 2005 | 03:35 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I have found if you have the main bearing caps off, its easy enough to use a regular socket. Might not be the best way though.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
