2.73 to 3.42 swap! Now speedo is off, cruise wont work!
Old May 11, 2005 | 09:23 PM
ledhead96's Avatar
I had the rear switched out in my 90 camaro [305 tbi, auto] The stock 2.73 rear died, so I found a 3.42 rear from an 84 camaro in a local yard.
Everything installed ok.
But I have the following problems:
1) Speedometer is way off: at 50 mph, my speedo says I'm going 60 mph [according to the construction zone MPH signs.... 8) ]
2) My cruise control quit working.
Any ideas on what I need to do to fix this mess?
Old May 11, 2005 | 09:58 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
cruise should still work,
get the correct speedo gears. what was the other car? auto or stick?
if it had a 700r4 as well then see if you can get the speedo gears. otherwise do a search. there is alot! of info on the speedo gears
Old May 11, 2005 | 10:10 PM
ledhead96's Avatar
Do I need to change my Vehicle Speed Sensor?
I don't know what kind of transmission the 84 camaro had. I was only able to get the 3.42 rear out of it.
I've read that the VSS helps run the cruise control....
Old May 11, 2005 | 10:17 PM
Engine: ls1, LB9
no you only need your stock sender. it is just a matter of switching the speedo gears on the sender, possiably on the trans. (but, you are in luck. the 700r4 is very easy to switch both gears)
the cruise only needs a speed signal from your sensor. if it thinks you are doing 60 (even though you are going 50) it still works. it just keeps the speed you are traveling
perhaps you were under the hood? moved a vac. line? did you work under the dash for any reason?
Old May 11, 2005 | 10:19 PM
Engine: ls1, LB9
https://www.thirdgen.org/techbb2/sho...eedo+calibrate
here this takes all the fun of looking for you,
https://www.thirdgen.org/techbb2/sho...edo+calculator
just read this post from the start. they give you info for the 700r4 as well. like 700r4.com for a calculator
Jorlain
Aug 24, 2022 05:11 PM
draco
Oct 4, 2015 09:25 PM
knight72
Aug 10, 2015 09:32 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
beachrodder
Aug 7, 2015 04:27 PM
