Transmission wont shift? vaccum?
Old May 17, 2005 | 07:21 AM
87Red305's Avatar
Car: 1987 Camaro
Engine: 305 v8
Hi, new to the Third gen forum! I got a Big problem with my 87 305, under full acceleration the tranny wil redline and wont shift till you let off the gas. now this is a BAD problem. Now it seems like a vacumm problem because at WOT the pressure will drop and its not strong enough to shift until you let off and the pressure builds up then it will shift. Now at first I thought OK, vaccum modulator right? well someone told me that our transmisisons do not work on vaccum. what now? thanks
Old May 17, 2005 | 12:20 PM
87Red305's Avatar
Car: 1987 Camaro
Engine: 305 v8
Comeon guys, summers coming and I wanna drive my camaro!
Old May 17, 2005 | 01:24 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Adjust the TV cable, search and you will find it. Also go pick up a manual.
Old May 17, 2005 | 01:54 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I assume you have a 700r4? If so there is no vacuum modulator.
The problem is worse.......usually this is a sign that your clutch bands are going bad. Which means your transmission may be on its way out. Or it could possibly be the TV cable.
Old May 18, 2005 | 06:22 PM
87Red305's Avatar
Car: 1987 Camaro
Engine: 305 v8
Ok so assuming that theTV cable adjustment doesnt work, wheres a good reputable place to look for a new transmisison for a good price?
Old May 21, 2005 | 02:51 PM
87Red305's Avatar
Car: 1987 Camaro
Engine: 305 v8
So is my transmission vaccum controlled or not, just to make sure?
Old May 21, 2005 | 04:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not
Old May 21, 2005 | 09:27 PM
formula1988's Avatar
Car: 1988 forumla 350
Engine: l98 350 tpi
Transmission: 700r4 2100 stall
I have the smae problem.
I installed a cold air intake on it the day the problem occurred.
I went to leave my house and stopped at a stop light
The car jerked forward like it was going to take off on it's own.
Then when i was in town i put it to the floor and when it got to about 30 mph it slowed down so i let off.
I tried it again and it would not shift into 3rd gear. Once it gets to a certain rmp it is like it is neutral.
I drove for five minutes today and it is worse,
it won’t hardly shift into second.
Could it be a vacuum sensor, or is my transmission going out.
I need help fast, I’m starting collage soon and i need my car.
Old May 21, 2005 | 09:48 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
yea. probably a tv cable adjustment or the like.. I know my 700r4 does have a vac line connected to it, I just always figured it was for the Torque Converter lockup
Old May 21, 2005 | 09:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, it doesn't.
Old May 21, 2005 | 10:36 PM
Transmission: 4l60e
I have had several 700r4's out. No vacuum lines. Just a couple wiring connectors. That is how the TC lockup is activated.
Old May 22, 2005 | 12:01 AM
Sorry. but it has a vac line on it. it is a completely non electronic 700r4. 1983 original. i have had it out as well, and no wires to it just the linkage for the selector, and the vac line that runs into it. I do not think they were electrnoically controled in 1983 anyhow.. i am pretty sure that came a little later.
Old May 22, 2005 | 12:05 AM
Car: 85 Trans Am
The 700R4 does NOT have vacuum on it. In it yea, on it NO. I belive the 350/440 and the 200 have vacuum. Get the casting numbers.
Old May 22, 2005 | 12:16 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you have a vacuum modulator, then you don't have a 700R4. You probably have a 3 speed TH200C.
Old May 22, 2005 | 03:48 AM
nope. it has 4 gears. and has the vac on it.. next time i remove the engine i will take a picture just so i can prove it lol.. that won't be till winter though when the next new engine goes in and i can toss the 305's
Old May 22, 2005 | 11:57 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'll be waiting. Make sure you get a picture of the pan.
Hotrodboba400
Dec 10, 2019 07:07 PM
angel2794
Sep 8, 2015 06:22 PM
rjcme
Sep 5, 2015 01:23 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
