transgo shift kit
Old May 23, 2005 | 09:38 PM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
transgo shift kit
ok so i was calling around shops here in ohio to get quotes on shift kit installation....soo the good thing was they all told me to stay away from B&M if i want my tranny to last....which is kool cuz im going with the transgo......but every place i called said they had to drop the tranny to do it and it would run bout $375....ok im not stupid and i know u dont have to drop the tranny and 375 is way to much.....my question is this....im not stupid when it comes to cars...im a mechanical person ive done my own valve seals..ive put cams in before and stuff like that......ive never touched a tranny tho....if i attempted to do this kit my self would i mostly likely mess it up ro is it fairly simple
Old May 23, 2005 | 09:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't have to drop the transmission, but it's a lot nicer than working over your head. Did the $375 include the cost of the kit?
Old May 23, 2005 | 10:50 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
It is possible that the kit they are talking about includes a revised spring for the front pump. Just a thought.
Old May 24, 2005 | 11:31 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
There is no need to remove the tranny for the pump springs.
You can install the kit while the tranny in the car unless if you are installing High Rev kit springs for 3-4 cluches.
Old May 24, 2005 | 11:38 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have a kit for sale if you have not bought one yet. Check it out.
Transgo Shift Kit for sale
Old May 24, 2005 | 12:34 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The TransGo shift kit is fairly complicated to install. You don't need to remove the trans from the vehicle, unless you get into other mods like the stiffer clutch pack springs or 10-vane pump guts. I would say $375 is absurd for a B&M kit. They are slam bam thank you m'am deals. The TransGo is a lot more involved, which is why it is a better kit. You actually have to drill some holes in the valvebody, not just the seperator plate. If I could do the kit on a lift I would say probably 4 solid hours of work. At $50 and hour thats $200. The kits is like $150 or so I think, so if that $375 includes the kit I wouldn't say it's far off. If it doesn't and all they are doing is the kit I'd say it's a bit steep.
If you feel like you're up to it just do it yourself. It isn't that hard, just time consuming. Plenty of people here run them, so if you get stuck you've got the resources to figure it out.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
