Are these the correct gears?
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I need some gears for my 4th gen rear, it was a 373 posi stock, so that makes it a 3 series carrier right? Which of these 2 are the ones I want? What are the differences? summit part numbers RMG-SGM7508 and RMG-SGM75008. Also what are the differences in these install kits? which one do i need? RMG-831044M and RMG-831016M . Thanks for any help summit is confusin me
Car: 4
Engine: 6
Transmission: 5
You need the 1044 kit; the 1016 is the 78-81 kit, and it has a smaller pinion head bearing. That bearing will fall right through a 82 up housing.
As far as the gears, I can't tell; the description looks the same. Something isn't right.
Neither of those numbers appears on Richmond's page. This is the number Richmond shows on their page.
the note at the bottom says "Not for use on 1999 and up F-bodies if it has the factory torsen positraction" and my rear is a 99..
Car: 4
Engine: 6
Transmission: 5
Then you better get some other kind of gears....
The problem with the Torsens, is that the high-ratio gears like that are quite thick, and block the place you put the "paddles" in through. There's a trick to it, it can be done with some brand of gears or other, but I don't recall the details. Ask over on www.ls1tech.com no doubt somebody over there will know.
are all 99 and up axles torsen posi's? can't get any answers at the ls1 forums
junkcltr
Aug 2, 2019 11:12 PM
hectre13
Aug 26, 2015 08:17 AM
