Rear End Gears
Old May 30, 2005 | 04:36 PM
Vincez28's Avatar
Car: White 1985 z28
Engine: 305 4b carb
Rear End Gears
HELLO Everybody,
I have a 1985 z28 camaro wondering what kind of rear end it has and what gears it has??? I'm looking to change the gears to 3.73 gears. what kind of things should i know about My rear End before i start shopping around for GEARS?
Thank-you!
Old May 30, 2005 | 06:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
check your RPO codes... they will tell you what gears you have. and i am not sure, but there might be a tag on the diff cover that says so too
Old May 30, 2005 | 07:23 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
RPO codes only tell you what the car came with stock. You need to pull the rear end cover and count the teeth or look for the pinion to ring gear ratio stamped in there. That is the only way to tell for sure what you have.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
