Clutch Chirping Sound
Subscribe
Jun 1, 2005 | 09:18 AM
Hi All,
I just had a new clutch put in my T5, and I noticed that when I am in 1st, 2nd, 3rd gear around 2000 - 3000rpm there is kinda like a sqeaking / chirping sound. As soon as I get above that range I dont hear it anymore, or if I push the clutch in, it stops.
Do I have a bearing going? or is something else way wrong? or is this normal for a new clutch?
Thanks in advance for feedback.
Reply 0
Jun 1, 2005 | 09:20 AM
I should add that its a stock replacement clutch, and the flywheel was resurfaced when the clutch was done because it had some scoring from the previous clutch.
Reply 0
Jun 1, 2005 | 01:57 PM
I take it that the noise speeds up w/ rpms correct?
Reply 0
Jun 1, 2005 | 04:46 PM
No, thats the wierd thing, it seems to go away above 3k rpm's and It doesnt always happen either.
Reply 0
Jun 2, 2005 | 07:45 AM
Does the car seem to drive ok? Don't take this the wrong way, but did you check the fluid level in the tranny and clutch? It doesn't sound like a pilot bearing, but it may be a throw out bearing. Just a guess though. Did you repack that bearing w/ grease?
Reply 0
Jun 2, 2005 | 07:51 AM
Sometimes all you have to do is grease the clutch fork pivot ball, there's a tech article that cover this on the main page.
Reply 0
Jun 2, 2005 | 08:34 AM
Yeah, the car drives fine. I didnt do the clutch myself, so as for whether the bearings were repacked or not, I cannot answer.
Im going to talk with the guy I had do the work and go from there. Thanks for the advice all
Reply 0
Jun 2, 2005 | 10:07 AM
Quote:
lol, there's actually a tech article? That's great. I'm going to write one up that tells people how to "Fill up at the gas station".
Reply 0
Jun 2, 2005 | 10:12 AM
just for sh*ts and giggles
https://www.thirdgen.org/newdesign/t...ngclutch.shtml
Reply 0
Jun 2, 2005 | 01:58 PM
Actually that sounds exactly like what is going on.
I dont have anyplace to do what the article says, so I will just live with it. It really isnt very bad, I just noticed it following having the clutch replaced.
My preferred mechanic is about 200mi. away, so I will get it done the next time I take the car back.
Thanks for all of the help guys. I really appreciate it. I was concerned that perhaps something wasnt right, that I should be worried about.
Reply 0
Jun 2, 2005 | 02:12 PM
all you really need is a jack, jackstand and a patch of something hard to jack on. I did this fix and it worked.......for a while The chirp eventually came back, but I plan to go back at it sometime this summer. FWIW I find it rather annoying. oddly enough, my m*stang does the exact same thing.
Reply 0
Subscribe
