Need quick help on th350
Old Jun 5, 2005 | 02:15 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I've had a th350 in my car for the last year and a half, and just recently ordered a new converter for it.
Now I'm worried I have one of the lock up converter transmissions...
The transmission is out of a 1979 chevy 1/2 ton truck, i got it for the long tailshaft, so i can re-use my driveshaft. I just heard that all the truck th350s were lock-up??? Which wont work with my new converter
Please someone help me clarify this
Edit... there are no wires or anything going into the transmission, its just got a vacume line. I dont know jack about lock-up transmissions, but if it was, shouldn't there be some type of wiring going into it, or at least some type of electric control? I removed it from the truck, and there were NO computer or wiring controls what-so-ever in the truck originally. Please tell me I'll be ok
Old Jun 5, 2005 | 02:40 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sounds like you'll be fine. besides you can put in a non-lockup converter in the lock up trans from what i was told . although if there were no plugs on the side of the trans like a 700R4 has then i wouldn't worry about it.
also no such thing as a lockup trans in 79, i believe it started 80 or 81.
Old Jun 5, 2005 | 05:28 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Alright, no wires = no lock up
Good to hear!
Old Jun 9, 2005 | 10:48 PM
Nordbert's Avatar
TH350C has a machined pilot with o-ring groove on the input shaft and different length stator. The converters won't interchange. A lockup converter has a raised circular area
on the front where the clutch is located.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
