Transmission Brains
Old Jun 13, 2005 | 01:04 AM
monzter_327's Avatar
Car: Airbus A320-214
Engine: 2 X CFM56-5-B4 (27,000 lb. thrust each)
Transmission: What's a transmission???
Transmission Brains
What are the inputs (electronic/electrical/mechanical) that a TH700R4 needs from outside the transmission itself in order to function properly?
My '82 Firebird will receive a SBC transplant to replace the 2.8L V6. I would like to use a 700R4 behind it to minimize drama during the conversion.
The engine itself will be fully analog with only the ignition being electronic (MSD.)
Please tell me I don't need no steenkin' computer to make the tranny work.
Thanks,
Mike in Manila
Old Jun 13, 2005 | 01:10 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The only transmission controls are the selector cable, TV cable, and TCC wiring.
Old Jun 15, 2005 | 11:25 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yeah, it's pretty simple. Ideally you need a relay and some wiring. There are instructions in the tech section that will tell you what you need and how to wire it up.
Old Jun 15, 2005 | 11:26 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You don't need no steenkin' computer to make the tranny work
Old Jun 16, 2005 | 04:53 AM
Thanks to all who have replied so far.
I did a whole bunch of research years ago when I owned an '86 Trans Am. I recall there was a certain year before which the TH700R4 had a problem with its internal hydraulics in a high performance application.
Is there an 'ideal' stock 700R4? I fully understand the risk involved in buying a used tranny. I would like to minimize this risk by limiting my choices to the more durable versions of this tranny.
Any quick suggestions for kits to improve the unit will be appreciated. Suggestions for ready-built aftermarket units will also be appreciated (just in case I win the lotto.)
TIA,
Mike in Cebu
Old Jun 16, 2005 | 09:36 AM
Pre'86 units without the aux. VB are often criticized for being less durable than later models. Your best bet is to get the latest version you can, 700R4s just got better with time. A '93 trans would be great, just make sure it isn't a 4L60E.
Pro-Built's kits are the best by far. You'll get a durable, sweet shifting trans. The cost is up there, but the kit provides far more than any of the others I've seen (inlcudes a TransGo shift reprogramming kit and new 10-vane pump guts among other things). Everything is hand selected to work together based on Dana's years of experience. He had input into designing a lot of the parts in the kit.
Old Jun 19, 2005 | 06:41 AM
Thanks to TKO.
Does ProBuilt have a website?
Mike in Manila again
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
