1986 and up flywheel change???
Old Jun 20, 2005 | 07:41 PM
andys86ta's Avatar
Car: 1986 trans am
Engine: 300hp 355cu. inch
Transmission: 350 turbo with shift kit and ratchet shifter
I just installed an 1986 transam T5 in my car and I have vibraton with the car parked clutchpedal to the floor, at a bout 2500 rpms and up. What is the difference in the flywheels from 1985 and down versus 1986 and up? I have a built 350 with a block and crank from late 70's and I am wondering if i need an older flywheel. And yes I put a pilot bearing in the crank.
Old Jun 20, 2005 | 08:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The flange on the crank changed when the 1 piece rear main seal was introduced. You'll need a flywheel for a 2 piece RMS crank.
Old Jun 20, 2005 | 08:15 PM
andys86ta's Avatar
Car: 1986 trans am
So this would have nothing to do with a vibration? The clutch P Plate and throughout bearing were new.
Old Jun 20, 2005 | 11:14 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Is it when the car is in gear but the clutch is pressed, like sitting at idle before taking off (or is in rpm specific, I know you said 2500)?
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Pilotrick50
Sep 2, 2015 12:48 PM
19irocz85
Aug 31, 2015 10:31 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
