I have 2.73s and 2800rpm stall
Old Jul 2, 2005 | 04:07 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm currently using a 2800RPM stall Vigilante in my set-up which still has the standars 2.73s in there. The car feels pretty sluggish until you really start to squeeze the gas or all out floor it. I'm guessing this is because of the 2.73 keeping the RPM down so low?
Robert
Old Jul 2, 2005 | 04:23 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
Orrr it could be your 2800 stall :P
Not particularly desireable for street duty, you should have to give it more gas to get it going
but of course better gears would help because it would just require less power to get it moving
Old Jul 2, 2005 | 04:34 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
with such a high stall teamed with those sorry 2.73 gears, im surprised you even get it to move from a stop lol!. A lower stall would help a bit with those gears but since you already have the converter installed, do the sensible thing and get some 3.42 gears(your stock tpi will not like anything steeper). If you want the maximum gain you can spend a little more and get into heads/cam work and then you should see a noticeable gain.
Old Jul 2, 2005 | 05:13 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
I've already got heads/cam/intake/exhaust etc. Hence the 2800 stall. The only thing I have yet to touch is the stock 2.73s. I was thinking of 3.23s as it still keeps some top speed potential.
Old Jul 2, 2005 | 05:52 PM
i'd go with 3.42's at least, better acceleration and you're still not killing your top end...get the best of both worlds.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
