Trouble removing T5 extension housing
Old Jul 5, 2005 | 07:13 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I attempted to install my new speedo gears but I could not separate the offset shift lever from the shift shaft. My install instructions said that tapping down the roll pin (circled in pic) would free it from the shift shaft. When I took the shifter off the roll pin had already been pushed/tapped down flush with the shift level housing. It didn't budge and I didn't want to damage it so I left it be for now. Needless to say I couldn't remove the extension housing without being able to slide the shift lever from the shift shaft. What am I doing wrong? Thanks in advance guys.
Attached Thumbnails Trouble removing T5 extension housing-p7050001-red-oval-.jpg
Old Jul 5, 2005 | 08:57 PM
Brock's91RS's Avatar
Car: 87 IROC
Engine: mini-rammed 350
Transmission: WC T-5
Get a drift punch,just slightly smaller than roll pin,and drive it THRU the clevis/rod assy,it will be laying in the top part of the case after you pull it apart(same area n as it is now,just underneath)
Just make sure you gather the pin/and theres also a ball bearing and spring in there too
Later
Steve
I just did this to my T-5 this weekend
Old Jul 5, 2005 | 09:18 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Thanks for the reply. I tried a few times to punch the pin down but it didn't budge. I will use a different punch next time aling with a little more elbow greese. It doesn't even appear to be a pin as the inside is hollow with a slit down the side.
Old Jul 6, 2005 | 12:43 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Correct, that is a "roll pin."
The correct tool for the job is a roll pin punch which has a half sphere located at the centre of the flat face of a drift punch tip.
Either you're being a girl about this, or someone boned you and installed a second roll pin, in which case you're hosed. If the car shifted fine before, it's the former, not the latter.
Old Jul 6, 2005 | 08:57 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The car shifted fine before so I must need a bigger hammer and a different punch. Thanks for the replys guys.
Eric2ndGen
Nov 5, 2015 01:51 PM
Fred SS
Oct 12, 2015 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Briandrex
Oct 5, 2015 06:20 AM
roysatikas
Sep 22, 2015 08:15 PM
