speed sensor
Old Jul 12, 2005 | 04:52 PM
blackroc68's Avatar
speed sensor
I swapped a 273 10 bolt out of my 88 trans am and installed a 345 ratio 9 bolt can anyone give me a part number for the correct speed sensor. tire size .is 245-50-16.
Old Jul 13, 2005 | 02:37 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
call the chevy dealer and tell them you need the speedometer gears that are close as possible with the following specs:
drive gear 15 tooth
driven gear 40 tooth
cost me $4 bucks each
you will have to pull *** end of the trans off to put the drive gear on, you have to change the drive gear when you jump that high in gears. original tooth is 17/36. this is for automatic trans only.
Eric2ndGen
Nov 5, 2015 01:51 PM
angel2794
Sep 8, 2015 06:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
