Bell Housing to Trans Boplt up Problem!
Car: '83 Trans Am
Engine: Carbed 350 290hp 350ft/lbs
Transmission: wore out T-5
Ok guys,
I bought a used t5 out of a 96 v6. My car came w/ a T-5 in 83.
Thought this would be a pretty straight forward swap.
NOT!!!
Different bolt pattern on the bosses to the bellhousing.
Does ANYBODY know what bell housing i can use and where i can find one cheaply?
NOT!!!
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
the fourth gen v-6 came with a t-5. but the bell housing was different. you need to use a bell housing from a v-8 camaro or f-bird. I do know you need a v-8 bell housing to mount up a t-5, as the v-6 is a totally different bolt pattern.
Car: `86 SS / `87 SS
There isn't a SBC bellhousing which has the Ford T5 bell to trans pattern on it. Sorry. Go get the right transmission now.
Car: '84 Z28 & '73 camaro LT
Engine: 1960 283, eaton m112 blower
Transmission: none at present, will be manual
Axle/Gears: 3.73:1 lsd
I saw on ebay once an sbc bellhousing with what looked very much like the ford t5 pattern, if it was any different the naked eye couldn't tell. I should also say that it was from a production car, not aftermarket
Car: '83 Trans Am
No guys, the tranny came out of a '96 v6 camaro. I beleive its a W/C t5. and yes OBVIOUSLY, the bell housings are different. What i need to know is where can i find a bellhousing to bolt this thing to that will mate behind a SBC. (heheh i said mate and behind in the same sentence.)
cmon somebody has to have a clue here somewhere.
1992 Trans Am
May 10, 2023 07:19 PM
