tv cable
Old Jul 19, 2005 | 11:19 PM
bonz's Avatar
Car: 89 GTA
tv cable
I want to adjust the TV cable on my trans am to firm up the shifts, I had it done on my last one and made quite a bit of difference. I was wondering though if you can damage the tranny be going to far or if there are any adverse effects of doing this.
Old Jul 19, 2005 | 11:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The TV cable isn't for adjusting the firmness of the shifts. It has one correct position. If you shorten the cable, it will ratchet forward into the correct position. If you lengthen it, your shifts will be early and soft which will lead to early clutch failure.
Old Jul 22, 2005 | 12:59 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Where is the TV cable and how do you correctly adjust it ?
Old Jul 22, 2005 | 01:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check the tech articles or do a search, it's been covered dozens of times.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
