Is This Right???
Old Aug 5, 2005 | 10:40 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Is This Right???
About 2 months ago i installed a trans-go reprogramming kit. Second gear would hang up big time till i hit 5000 RPM then it would shift.
Check out what i found that i think is wrong:
Old Aug 5, 2005 | 10:44 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
These are the spot where the 2 check ***** sit, it seems like the ***** made a grove in the plate if you can tell, but is that normal or should i go ahead and get a new one?
Check out this AUX Valve body check ball. its stuck in there i know thats not right
I just need someone to help me verify the problem, also i found a check ball in the wrong place and a small tear in the gasket. Could this be my problem? Thanks
Old Aug 6, 2005 | 09:29 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
can someone please help me out here. I really need to get his doen guys.
Old Aug 7, 2005 | 03:48 AM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
get that stuck ball out first, its not suppsoed to be there sitting tight.
if that plate is damaged, throw it away and get a new one, next let somebody help putting it together, so 1 of you can make sure the ***** are in place before putting it together.
good luck
Old Aug 7, 2005 | 09:41 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Thanks for the response bro. I got in already and it works GREAT!! Thanks again.
