Rear size
Old Aug 6, 2005 | 03:41 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Rear size
How often was the 3.70 9-bolt used in the Trans Am's? I just picked one up at a junkyard from an '85 that was a 5-speed/LB9 (verified by the F in the VIN) car, 9 bolt still has the tag on the rear and when I ran the S/N it comes back as a 3.70 posi rear.
Was this an unusual option on these cars?
Old Aug 6, 2005 | 04:21 PM
ede's Avatar
ede
don't think the 9 bolt was used untill 87
Old Aug 6, 2005 | 05:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A very limited number of cars got a 9 bolt in 1986 but chances are you'll never find one that did. 1987 the 9 bolt became the performace option. The 3.70 gears were never a factory installed option. They were only available as an over the counter item from GM.
Old Aug 6, 2005 | 07:34 PM
Klortho's Avatar
Car: 1987 GTA
So I can assume that this was a good find? I went back out and looked at the tag again, it says Ratio 3.70:1 and the part number (10032274) and the serial number which I can't make out. The 10032274 shows as an '85-'86 Borg Warner part number where in '87 the 3.70 wasn't offered and the part numbers went from like mine 10032274 to 4ET, 4EW etc etc.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
