wondering how much syncronizers cost
Old Aug 25, 2005 | 06:03 PM
chibe69's Avatar
Car: 1989 camaro
Transmission: 5 speed
wondering how much syncronizers cost for 3rd and reverse
5-speed 1989 camaro rs???
Old Aug 25, 2005 | 11:13 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
There is no reverse syncro, so I'll save you the money there.
Old Aug 26, 2005 | 07:28 AM
DanS's Avatar
http://www.5speeds.com/ has the best prices that I have found.
Old Aug 26, 2005 | 10:18 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
If you're going in to do synchros rebuild the trans. The complete kit is $175 or so with all bearings, synchro rings/springs/dogs, bushing, seals, roll pins, oil funnel, snap rings, etc. Basically all the parts except the gears and shafts. Splurge $15 on the manual too. You'll have a trans that won't need to come apart for years when you are done, if ever again.
If you are having reverse clash problems you probably need a new reverse idler and a new 1/2 slider. The idler is about $35 and the slider is like $70. Years of ham fisted goons jamming the trans into reverse without putting it in a forward gear first has probably damaged those parts. There is no synchro for reverse, so if the slider isn't lined up you get gear clash and damage to the idler and slider, which has the reverse gear teeth cut onto it. The only American made trans I've ever seen that had a synchronized reverse is the T56.
birdman_29
Jan 7, 2017 08:24 AM
jerflash
Sep 22, 2015 09:59 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
SG91camaro
Sep 5, 2015 10:27 PM
