Differential to a richmond gear
Old Aug 29, 2005 | 01:09 PM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Hi guys!
I dont now were i can find a diff to my 10 bolt 7.5 rear,there seemes to be that the richmonds ring are a little bit thicker than the stock,have non of you a richmond whit a diff?By the way i have a 3.73 gear.
And what type of diff can you rekomend.
Thanks for any replay.
Old Aug 29, 2005 | 04:43 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Are you raising the gear ratio from a lower gear like say 342 or something lower . If you are the pinion gear get's smaller and I think the ring gear get's thicker to meat up together (you will still have to set the proper backlash ). The ring gear should have the same bolt pattern as stock . If you want to change the carrier look in to the Eaton . www.ringpinion.com .
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
georgiaslim45
Sep 9, 2015 08:12 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
