Part Numbers for T56 VSS and Reverse lights connectors?
Old Sep 6, 2005 | 10:32 AM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Need to finish wiring up my T56. I need to order the T56 VSS connector and the connector for the backup lights. Anyone have these part numbers?
Old Sep 6, 2005 | 12:41 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
ok for the vss go to autozone or checker and get the coolant temp. sensor plug, it fits perfect and works, for the backup lights you can you the t5 plug. good luck
Old Sep 6, 2005 | 09:19 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
you might want to check our new sponsor tpiparts. they have connectors for some other stuff like the maf and map, iac and so forth. they might have what you need. if they dont have it, car quest or bumber to bumper most likely will.
good luck
Old Sep 7, 2005 | 08:43 AM
mult68's Avatar
Engine: 305 TBI
Awesome thanks a lot. And I converted from a 700r4 to the t56....would the reverse plug happen to work from the 700r4?
Old Sep 7, 2005 | 06:15 PM
7plagues's Avatar
you know i believe its different. but ill wait for some more experienced help. i went t5-t56
Old Aug 3, 2009 | 07:46 AM
pmcruz781's Avatar
Car: 1986
Transmission: t56
Axle/Gears: Auburn 3.73 posi moser axles
Re: Part Numbers for T56 VSS and Reverse lights connectors?
These are all the gm part numbers for the stuff you need
Reverse lockout plug- GM 12101857 VSS GM 88987993 and Reverse light GM 12085485.
Old Aug 3, 2009 | 07:47 AM
pmcruz781's Avatar
Car: 1986
Transmission: t56
If you are going to use your stock speedometer you need a Dakota Digital box so that you can caliabrate it.
1992 Trans Am
May 10, 2023 07:19 PM
twest2k2
Aug 24, 2015 11:26 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
armybyrd
Aug 10, 2015 09:23 PM
Omega
Aug 10, 2015 12:46 PM
