Slips out of OD
Old Sep 6, 2005 | 12:07 PM
robotic_junky's Avatar
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
Slips out of OD
Since the tranny has been in, when I'm driving in OD, at 2,000 RPM, and I let off the gas a little bit,to slow down. It will slip into 3rd gear then I have to rev the motor back up to get it to shift back into OD. My VSS doesn't work, Code 24 plus speedo doesn't work. My scanner says my TCC isn't locking up in any gear. When I'm trying to cruise at 2,000 RPM on the highway, the scanner says I keep going back and forward from 3rd to 4th, but it feels like it's still in one gear. Also the scanner says my park/neutral switch doesn't engage. I can't start it in Neutral, only Park.
Guesses, from all the entries I read on here, came up with these: VSS, brake pedal switch, idle stop solenoid, and park/neutral switch.
Any other guesses?
87 GTA, 700R4 B4C package, 3.73 gears, 355 TPI, no A/C or emissions.
Also it idles at 1,000 RPM in Park and Neutral and drops down to 450-500 RPM in other gears.
db057
Jan 10, 2020 08:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
camaronils
Sep 20, 2015 02:57 PM
Fox118
Sep 12, 2015 09:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
