How much diff. fluid do I use?
Old Sep 7, 2005 | 01:49 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I got some differential fluid and posi- additive bottles from AutoZone. How much of each should I pour into the pumpkin, or should all of it go in?
Btw, it's a regular 10-bolt 3.42 posi rear from an '89 IROC.
Old Sep 7, 2005 | 10:13 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Typically 4 oz. of the posi additive, then fill the diff to the bottom of the fill hole.
Old Sep 7, 2005 | 10:21 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
put the bottle of posi additive in, then fill it to the bottom of the fill hole.
Old Sep 9, 2005 | 02:39 AM
Car: 1994 Trans Am
To the bottom of the fill hole, does it pour out the bottom or something? How does it hold in there then?
Old Sep 9, 2005 | 08:04 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Correct me if I'm wrong, but the fill hole is usually on the SIDE of the pumpkin and therefore it's horizontal. You can only fill level with the bottom of the hole. Hope this clarifies the situation.
Mark.
Old Sep 9, 2005 | 09:02 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
While we're on the topic, I am going to change my gear fluid also. For the additive, I am going to use Trans-X Posi-Trac that comes in a 7 oz. tube and replaces Gm# 1052358. Should I use the entire tube?
My instinct and MrDude_1's post leads me to say yes.
Old Sep 9, 2005 | 09:11 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Mark.
you got it..
its on the side.. you fill it until the level is even with the bottom of the hole on the side.... then you put the plug back in.
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
