9bolt question
Old Sep 7, 2005 | 02:14 PM
3rdgen92maro's Avatar
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
9bolt question
does anyone know where i can find parts for my 9bolt rear. receintly it has had a tendency to spin the passanger rear. im guessing that i need new clutches in the lsd
Old Apr 25, 2009 | 10:53 AM
89GTASC's Avatar
Car: 89 TransAm GTA
Engine: 5.7 TPI
Transmission: AUTO
Axle/Gears: 3:27
Re: 9bolt question
9BOLT.COM DOES, dont do what i did and keep driving it w/the clutches slipping, cuz i eventually broke the gear set teeth.
i mean ok to drive, but don't keep punching it in to break the car loose.
Old Apr 25, 2009 | 05:13 PM
big gear head's Avatar
Re: 9bolt question
The 9 bolt uses a Borg Warner cone type differential that doesn't have replaceable clutches. You can get new cones for it and shim the gears, or you can put the old cones in a lathe and turn down the ends and shim it. There is information on here somewhere about how to do this.
Old Apr 26, 2009 | 02:26 PM
cbmotorsports's Avatar
Car: 1988 GTA
Engine: 5.7
Re: 9bolt question
If you want to order from 9bolt.com I suggest email him for all you want and wait for him to email you back. Sometimes it takes a bit for him to reply but its worth it!
Old Apr 26, 2009 | 02:31 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: 9bolt question
I am parting out 2 9 bolt carriers if you need any parts. I even have 2 sets of machined cones for sale.
Old Apr 27, 2009 | 07:17 PM
huffediroc's Avatar
Car: 87 iroc
Engine: 350 with weiand 144
Transmission: tremec TKO 600,mcleod street twin
Axle/Gears: strange s60
Re: 9bolt question
how bout that pinion yoke? Does yours have weights up in the sleeve?
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
